Message |
So, the most recent ZCar project has been to pull the engine, replace all the old stuff, and put in a fancy new wiring harness. After a year of piddling with it, I finally got it going. On a Friday night, the car came to life on the second key turn! Saturday: drove it to a car show about 30 miles away, then Sunday: drove it around the lake the next day (3+ hour trip, and high speeds!) Thursday I drove it to work and it was just fine, but when I started it up on the way home, it wasn't running on all 6 cylinders. Felt like 4, with the 5th one coming and going. The engine was rocking around, sputtering, no power, etc. Today I went back to the garage to fool with it and this is what I've found: ECU Code: 13 - Coolant Sensor (Car burped coolant the first couple of times I started it, but never overheated) - Car dies after the first cold crank (VIDEO: https://youtu.be/AqkKmsorbFE ) - Injectors are all ticking - Disconnecting coil packs effects engine idle (Cyl 2 made a small difference in idle, unlike the other 5 cylinders that made a bigger difference when disconnected). - I didn't get the rear main seal done properly last time, so it's leaking . Does the Z have a low oil pressure warning light? Finally, listen to the revs, hear the rattle? (VIDEO: https://youtu.be/xBSuDrIw8rE ) I'm going to order a new coolant temp sensor. Can anyone help me put this all together? I'm not sure if I'm staring at one problem or multiple problems. I haven't driven it yet today, but it still feels like it's bucking around the engine bay somewhat. Thanks again for everyone's time. -- Stokens AR
If I would have known addiction was this expensive I would have seen a shrink a long time ago. --BadZCar (FL)
